no green light on beckett oil hot water heater
Old 05-12-09, 01:29 PM
H
Wink no green light on beckett oil hot water heater
Hi, I had a power surge/interuption and the reset on my beckett oil burner for my hot water doe not show the green light, its like its not there at all. I have checked and I have power to the cad cell, after that, not sure. Anyone have any ideas, I would rather try some things firt before I call the oil repair man tomorrow.
Thanks
hammer
Old 05-12-09, 02:52 PM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
Newer burner? The control that has the LED on it, does it say GENISYS on it?
Old 05-12-09, 06:44 PM
Grady's Avatar
Received 39 Upvotes on 37 Posts
No green light
This is a stupid question but I have to ask: Do you have hot water?
Old 05-12-09, 07:30 PM
rbeck's Avatar
Received 61 Upvotes on 51 Posts
Good question Grady. the green light is only on when the burner is running and the cad cell sees light.
Old 05-12-09, 07:37 PM
Grady's Avatar
Green Light
Rbeck & I seem to be thinking along the same lines. If the aquastat is satisfied, the burner won't be running therefore no green light.
Old 05-15-09, 06:28 AM
H
Wink Fixed the problem
Turns out the interupt relay (cad cell) was bad, replaced that box and it works fine.
Thanks for the reply's, and no I had no hot water at that time gray. Also, just a not on those beckett 7184b interupt relays, if it is in normal cycle, the green light flashes 2 seconds apart, if your out of oil an nee to bleed the line, it flashes half second apart. If the cad cell is bad, the light stays off. I had a tech come in and fix me up, that was his statement about the cad cells on the beckett .
hammer
