Reusing Old Hot Water Heater After Upgrade
I recently upgraded to an indirect-fired hot water system, and I still have my old, electric hot water heater. I could just take it to the recycling center and be done with it, but I'm curious if there are any other ways to make use of it.
I have a pool--could I put the hot water heater in the pool shed and connect it to the pool's filter to heat the pool through winter?
I also have a garden--could I build a garden shed for the water tank and use it as a set-and-forget irrigation system?
Are the any other uses I'm not thinking of that could make use of this appliance?
I'm not sure how you would use this in a garden ...
A hot water heater could be a nice accessory if you have a detached garage and no hot water there.
If you were adventurous, you could fill it with antifreeze, use a pump, and use it for a small snow-melt area.
There are also some guys on-line using old water heaters for their bio-diesel lab setups.
You could use it as a buffer tank in your heating system. It would then be like a battery. When the system is heating it runs a little longer to heat of that tank (the electric elements aren't used) and then after the boiler stops but while the circulator keeps running, it then discharges all that heat to keep the boiler off longer.
