No voltage at gas control valve
Old 10-01-09, 12:48 PM
I have a peerless boiler with honeywell controls. I turned the heat on for the first time this morning and furnace did not fire. Pilot is lit, 24 volts at therm connections in aquastat relay. But .30v at burner connections in relay. Also .30v at gas control. all limit switches show continuity,and damper control and circulators start up. Do i need a new gas valve or more than likely a new relay? Can really only afford one or the other, gas valve was replaced last season. Thanks in advance. Walt.
Old 10-01-09, 01:21 PM
NJT's Avatar
NJT
NJT is offline
Received 1 Vote on 1 Post
What's the model of the boiler ?
Old 10-01-09, 01:54 PM
MC-04-STDC-WPG as best as can be deciphered it is a 1994 model.
Old 10-01-09, 04:29 PM
NJT's Avatar
NJT
NJT is offline
Walt, is this PDF for your boiler?
http://peerless.ag-is.com/DesktopMod...hod=attachment
Model MC, probably is...
Your boiler have a 'standing pilot' or 'spark ignition' ?
If it's a standing pilot, my first suspect would be the thermocouple has bought the farm.
