9D backflow preventer leaking
After shutting off my house main water supply and turning it on, the 9D backflow preventer above the furnace starts leaking from the side port. It drips about one drop per five seconds. Is it because the dirt gets to the valve seat? I tried flush it by lift the lever of the pressure regulator valve but it didn't work. Can I remove the valve and clean it? Is there any procedure I need to follow? Please help! Thanks.
Received 38 Upvotes
Yes, you can remove the 9D and take it apart for cleaning. It may not be any better after re-assembly than it is right now but nothing ventured, nothing gained.
I don't know if rebuild kits are available for this or what their cost is compared to a whole new backflow preventer. It may be easiest to just replace it with a new unit.
Hopefully the guys that actually deal with these things on a daily basis will have a better answer.
9D valve
Thank you, Furd.
Do I need to completely drain the water before I remove the valve? After I reinstall the valve how do I fill the water into the system and get the air out? Anybody know? Thanks.
I'd bet that the backflow preventer can be isolated. On the inlet side, maybe you'll have to turn off the whole house supply? Downstream, I'd expect an iso valve ahead of the boiler. Assuming this is all correct, you shouldn't have to drain the system.
Watts sells a repair kit. I would probably opt for a new unit. Or, you might consider getting a repair kit and a new unit - you could then repair the old one and have a spare.
The fill valve may have a lever that, when lifted, fills at a faster rate.
Then go to each heat emitter, and look for a bleeder valve on one end or the other. Bleed until you get water, not air.
You open the valve that feeds city water to the automatic fill valve - that's it.
I don't have bleed valve at each baseboard. There is only an air vent above the expansion tank. How does this valve work? How can it get rid of the air from upstairs? I am afraid after replacing the 9D, the air is trapped upstairs then I am in trouble.
Received 38 Upvotes
If your connection is city water shut-off valve>9D>pressure reducing valve> boiler system you can likely remove the 9D without having any significant amount of air entering the system or needing to drain any water from the system.
Close the city water valve and then disconnect any unions to allow removal of the 9D. The pressure reducing valve (PRV) will act as a check valve to prevent boiler system water from flowing backwards. After reassembling the 9D into the system open the city water valve and check for leaks. Ideally there should be a union just before the PRV and you can leave this slightly loose to bleed any air from the 9D with the city water valve only slightly open, then tighten the union and open the city water valve wide. Any air introduced should be caught by the air elimination device.
Update: I bought a 9D from Home Depot ($32) and replaced the old one. The old valve is very dirty, gasket of the secondary check valve is broken that makes it leak (there are two check valves in the 9D). My heating system works fine now.
Many thanks to furd and Mike Speed 30 for your help.
