? about steam/hot water hybrid systems
Old 11-21-09, 02:54 PM
F
First time caller and love this site already.
Not much you can fool me on with hot air heat but that is easy.
My daughter just bought a house originally with steam heat and the addition has a hot water baseboard leg.
The boiler is a new GSA and it provides both the steam and hot water for the baseboard system.
I have been studying the ins and outs both steam and hot water systems but couldn't find much information about a hybrid system like this one (I don't even know the poper name for the mix and match set up),
What I have not been able to catch up to now is the following.
I know steam likes a pressure of between 1/2 and 2 pounds and hot water comes in at around 15 pounds.
How is this pressure differential separated in the boiler. I can only think that the return for the hot water goes directly into the liquid portion of the boiler at about the same 15 pounds and I have not been able to FIGYA how the pressure between the steam and hot water remains independent?
Anything else that is unique to this type of system that I should know about would be helpful also.
Thanks in advance for any help provided.
Old 11-21-09, 03:56 PM
D
Received 1 Upvote on 1 Post
Check out Steam / Baseboard / Indirect
Go into the tech menu. They have a lot of good information on both hot water and steam systems. They briefly describe how to set up a steam system that has hot water baseboard and an indirect water heater. It may answer some of your questions.
