is zone valve necessary?
Old 12-31-09, 06:57 AM
K
I have 2 zones baseboard hot water heating system at home. Looking at the boiler setup in the basement, I could see
+one expansion tank
+two flow checks
+two pumps
But I did not notice any zone valve right before the 'flow check'. Thus, my question, is zone valve necessary?
I'm thinking of adding a third heating zone. Should I add a zone valve when I add the third zone?
Old 12-31-09, 07:33 AM
If you have a separate pump for each zone, you don't need zone valves.
Old 12-31-09, 10:05 AM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
As Mike said you won't need a zone valve, but you will need a pump and a way to control that pump.
