Circulation pump makes rattling sounds
The circulation pump from my central heating system, which is about 10 years old, started making rattling noises yesterday and it continues. So far it's still working, but does anyone have any idea how much time I've got left? Would it make it until spring or could it break down in the following days?
Want to replace the complete system around May, that's why I'd like to postpone replacement of this part.
If it's a small wet rotor circulator, then it's going to fail.
The cartiridges can usually be replaced, but many find you can buy a new circ for little more.
If it's a larger open motor with coupling type, check if you can add oil and do it fast.
Finally replaced the thing
Thanks for the answers. I had a close look at the system and saw that it would only take half an hour to replace the pump. So that's what I did, helps me to sleep better at night...
