cirulator advice please
i am going to put in a new pump to replace the old and leaking and noisy B&G 100. My choices are the taco 007 and the 008. i have a 3/4" copper baseboard hot water system, 4 zones, with the longest loop having an effective length of about 350 feet. by my calcualtions, at a flow of 4 gpm, the head is 13; at 3.5 gpm it is 10. any thoughts on the 007 vs the 008? i assume i can use the current flanges with either pump? is that correct?
What doesnt look right with your calcuations i=s
Head 13 =4 gpm
Head 10=3.5 gpm
As your system friction head resistance to flow decreases your gpm will increase. this is backwards from what you stated.
H1/H2 = (W1/W2)2 ........... 2 is suppose to mean squared
H= head in FT
W=GPM
Personally i would stick with the B/G pump If its a ball bearing design switching to a sleeve bearing for less noise.
B&G is a good pump, what kind of noise is it making sound like marbles? or more squeaky?
Rebuild kits are available for B&G 3-piece pumps.
If your choice is to replace your pump, and the 100 was performing satisfactorily, pick a replacement with a pump curve close to the 100.
As far as flange compatibility - yes, that's a definite maybe! Check the pump dimensions available on the pump manufacturers' websites.
sorry. my post was way too confusing.
the old B&G was installed, years ago, for only 3 heating zones [and i remote water heater]. I got rid of the wter heater andreplaced it with a 4th zone, which has the longest effective length of all [350 feet]. the B&G can handle a head of 8 at a flow of 4 gpm or less [flat curve]. this pump is now delivering only about 1 1/2 gpm in the longest zone. time to replace!!
if i want a flow of 4 gpm with the current zones, i need a pump that can handle a head of 11. the 007 cannot do this, although it can possibly handle a head of 9 at 4 gpm. the 008 can definitely do the job, but uses more energy. i do think the 007, at a flow of 3.5 gpm, can handle a head of 8.6.
so, do i get a pump slightly undersized or slightly oversized, since my design specs at 4 gpm fall between the two pumps?? is it ok to settle for 3 to 3.5 gpm flow [which is what the 007 will do]??
Personally If would use the existing Pump as a tool to figure out what your new system head would be for selecting a pump . Increase in gpm is a increase in velocity which increases system resistance. I will make up some numbers assume that your system head now 6 FT head= 1.5 gpm
using the formula i stated before you can predict what your new head requirements are at your new GPM of 4.
select a pump on these values as mentioned as flat as possible with the highest effiecency rating.
H1= actual head ( you need to measure it ) 6
W1= actual gpm 1.4
H2 = New head ( this is what you find using the equation i mentioned previously and you need for selecting a pump.
W2= New gpm 4. ( 0r what ever you you flow requirements are. IF you size your 4 and you need 3.5 you can throttle your balancing valve to obtain your new flow rate. basically you are Increasing system head .
Inceased gpm = increased velocity which = increased frictional resistance to flow.
This way there is no guessing what kinda of system head you will have when you install a new pump, and you need to know what your new head is for selecting a pump.
Maybe overkill but this is what i would do in a commercial application. Takes the guess work out of it.
W1= actual gpm 1.4
Forgot to mention when selecting a Pump take a look at your NPSH this is the point your pump will cavitate if it falls below this point. Lower the NPSH the better
NPSH= Net Positive Suction Head.
I'm interested in those multi-speed circulators. Perhaps a slight drawback might be that efficiency would be optimum at just one speed?
One advantage would be if you were unsure of the preferred gpm/head requirements for your system. Then, you could play around with the speeds.
Or, and this is interesting to me, what about switching speeds - based on the season, outdoor reset, etc.? For systems with zone valves, the speed could be changed depending upon the number of zones calling for heat?
The possibilities seem endless.
I really don't think they lose much due to the speed changes, I am no pump engineer but I would imagine everything has be optimized.
