Low furnace PSI
  #41
Old 10-21-10, 03:55 AM
X
Try these guys for foam, EPDM, etc.
EnergyFederation.org | Home
Heat shouldn't be too bad that it would cause failure.
  #42
Old 10-21-10, 02:54 PM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
Just for clarification, the heat probably won't affect the EPDM, but rather I was thinking about that 'double stick' tape that is used to adhere the stuff... I guess as long as the covers are making contact with it, as long as the covers are on, it won't fall out... you only need it to stick long enough to get the covers in place!
