Correct Max pressure for a steam boiler?
Closed Thread
  #41
Old 11-21-10, 08:34 PM
NJT's Avatar
NJT
NJT is offline
Upvotes Received: 1
You could also mount a second aquastat in one of the boiler tappings below the water line and use that same thermostat idea with a relay (like a Taco SR501) to switch between the two a'stats. This option would allow keeping the boiler at least 'warm' (say 120?) and would not take as long to come up to the higher temp setting (say 180), but a little more complicated, and a little more $. Maybe I'll draw some schematics if there's interest ...
Old 11-22-10, 02:22 PM
Upvotes Received: 16
Originally Posted by NJ Trooper View Post
Looking at the spec sheets, I note that the Wika gauge is spec'd for a maximum of 140, gaseous or dry media.
Furd, is the siphon adequate protection to keep the gauge gaseous or dry? No chance that condensate will find it's way into the gauge? ( I assume that's the purpose of the siphon, that, and temperature protection )
Good catch! No, a siphon will not keep the gauge internals dry.
  #43
Old 11-29-14, 04:36 PM
why would you say it is paper weight????
  #44
Old 11-29-14, 04:46 PM
NJT's Avatar
NJT
NJT is offline
Upvotes Received: 1
Because he's implying that it's NO GOOD for anything but a paperweight. In other words, JUNK.
This is a FOUR YEAR OLD thread, FYI...
  #45
Old 11-29-14, 04:54 PM
lawrosa's Avatar
Super Moderator
Upvotes Received: 3
Old thread has run its coarse.... Closed...
Please start new... Thanks..
Closed Thread
