Converting to gas from oil heat, and I have a chimney question.
  #41
Old 01-04-11, 02:30 PM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
Looks good! Thanks for letting us know. Stay warm in the New Year!
  #42
Old 01-04-11, 03:20 PM
T
One thing no one seemed to mention here.
You can easily change the entry point in the chimney.
Just push the liner up a bit make a new hole above the existing hole and pull the liner thru. Block up the old hole and your done.
Probably a little late eh !!!
  #43
Old 01-04-11, 03:37 PM
T
I seriously considered doing just that. The 12 degree outside temps, plus the fact that it was drafting vary hard convinced me that it worked and I didn't need to screw with it.
