Grundfos pump gasket
Old 11-18-10, 01:38 PM
L
My Grundfos circ pump gasket seems to be leaking. Can I use one of those "old fashioned" flat gaskets or do I need to get the "O" style that grundfos ships them with?
Thanks!
Laz
Old 11-18-10, 02:08 PM
Is it a flange gasket where a pipe connects to the pump? If a flange face is grooved for an O-ring, that's what you need to use.
You might try tightening the flange nuts slightly and see if that helps. You can open the pump connections and inspect the O-ring and see what's wrong, but best to have a replacement O-ring in hand or readily available before you do that.
Some Grundfos gaskets are available here: Grundfos Pumps , Pumps , Grundfos Cast Iron Pumps , Grundfos Bronze Pumps - PexSupply.com
Old 11-19-10, 07:06 PM
Grady's Avatar
Received 39 Upvotes on 37 Posts
The O-Ring type gasket is ideal if the flange is groove for one but a flat gasket will work. Sometimes I've had to use both to get a seal.
