Rinnai tankless used for radiant heat in cement floor.
Old 12-08-10, 06:59 PM
B
Does anyone know when you install a heater used for radiant heating if you should the water mixing back into the heated line? I think i am cooling the direct line with some return line water. I can send a photo to explain better.
Old 12-08-10, 07:05 PM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
I moved your post into a new thread, adding your post to an existing thread that was in progress and discussing a completely different subject just doesn't make sense. We call it 'hijacking'...
If I understand your grammar, the answer is YES, you probably should mix some return water with the hot water going out. Radiant systems SHOULD have lower temperature water running through the system.
Warm floors are nice, but HOT floors are NOT !
Old 12-08-10, 07:10 PM
B
I have the Rinnai set at 110 degrees.
