what is best ceiling material for in-ceiling radiant heat?
Received 0 Votes
I'm finishing off a section of my basement for a family room. I'm installing in-ceiling radiant heat And I'm wondering what would be the best ceiling material to cover it with.Drywall, Tong-in-groove, plank ceiling tiles(like the ones Armstrong makes), Tin or other? Thanks for the input.
Received 0 Votes
I'm assuming this will be a hot-water radiant ceiling? Info here: Modern hydronic heating for ... - Google Books
You can get much info Googling "radiant ceiling panels" or "tube and plate radiant ceiling." The major no-no is that the ceiling material must tolerate the maximum temp expected. For sheetrock, that is about 120 deg F. If you are using ceiling heating panels, the manufacturer should give you suggested installation instructions.
