Attn: Boiler Tech's
Old 12-16-10, 10:01 AM
Attn: Boiler Tech's
I have a Utica MGB boiler model no. MGB50HD Rev. 2
This is a nat'l gas, forced HW boiler.
I'm finding that the thermostat is not satisfied and the boiler is off.
I have observed on several occasions that the vent damper is getting hung up at ~98% open, I simply move it the other 2% and the boiler fires up.
Once the boiler fires up the boiler runs until the resevoir temp. hits the High limit (SP 190F) the damper closes (sometimes partially). The boiler of course won't fire again until the tank temp. drops below 160F.
My question is: Is the sticky vent damper my only problem, or do I have a circulaor problem too, causing the tank temp. to hit the High Limit switch?
The vent damper is a EFFIKAL RVGP-KS4
The cartridge circulator is a Taco model no. 007-F4
Old 12-16-10, 10:15 AM
lawrosa's Avatar
Super Moderator
Received 37 Votes on 32 Posts
When the boiler hits 190 it should shut down. This is normal. If you still have a call for heat the ciculator should still be running until the t stat is satisfied.If the t stat does not get satisfied the boiler will kick back on and heat to 190 again and the process will continue until the t stat is happy.
What is the model aquastat? 160-190 is a 30 degree swing. Usually its a 15 degree difference and yours may or may not be adjustable.
As far as your damper getting stuck and not hitting the end switch to fire up will need to be repaired or replaced. Find out why its hanging up.
Mike NJ
Old 12-16-10, 10:39 AM
Mike,
It's a Honeywell aquastat type-L8148E
I will examine the damper's mechanical ability, but I'm not much of an electrical guy. If the mechanical function is OK? Can I replace just the small motor or does it come as a one pice unit damper an all?
I appreciate the advise!
Dave MA.
Old 12-16-10, 04:28 PM
Received 33 Votes on 25 Posts
I think you will find it is a mechanical problem (binding) with the damper assembly. The motor that drives the damper isn't very powerful and if the damper sticks anywhere in its travel the motor will stall.
Old 12-16-10, 05:35 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
You replace the whole thing.
Are you sure that this is the correct part number?
EFFIKAL RVGP-KS4
It's not RVGP-KS F ?
Does this PDF file help?
http://www.effikal.com/rvgpksf_manual.pdf
