MPI KWH 124 Hot water heater... NO HOT WATER!!
Old 01-19-11, 11:04 AM
H
Hello, we just purchased a home with so many applicances that I have never seen before. One of them being a instantaneous hot water heater KWH 124. Can not locate manual anywhere and we do not have hot water. I keep calling service repairmen for the oil furnance and I'm running out of dough It seems that the unit is not kicking on at all when I open up hot water from the faucets.. there are no error codes and it does not display run. It just sits there and I am wonderin if kerosene is not getting to unit?? Please help
Old 01-19-11, 02:45 PM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
The only thing I could find out about your unit is that it was produced by Monitor Products.
Old 01-19-11, 08:09 PM
tldoug's Avatar
Found this on another forum (Google is your friend): "Monitor has not made a KWH in over 17 years, and have not made any parts in the same amount of time."
As I don't know the DIY Forums policy on linking to other forums in these threads, I will suggest that a google search for KWH 124 Water Heater will get you to the information you need, but may not want. Or, a search for the quoted sentence above should take you directly to that thread.
Old 01-19-11, 08:12 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
What I found is they have two web sites and you could e mail tech support to find the info you need. Or call them.
Monitor Products
Here one.
Monitor Products, Inc. - Vented Heating Systems
Heres the other. There old site.
Mike NJ
