Outdoor wood boiler leak
OMG!
I put radiator stop leak in my outdoor boiler!! I thought it was boiler stop leak...now what??
There is a pinhole leak on the top of the firebox....
Unless you are combining it with a high pressure device(condensing boiler) in your system NOTHING, other then it might stop the leak for a little while. All openings on a boiler for water flow will probably be larger then most openings in a car cooling system. But I would think you should weld that pinhole instead and check the condition of the rest of the box.
If you have propylene glycol in the system i will bet nothing will stop it from leaking.
I find it is about the hardest thing to seal.
If your boiler sections are cast iron, you gonna need a good welder to fix it, and even then I doubt it will ever work.
From what Ive heard from the ppl at work that have had o/d boiler leaks, it pretty much always ended up welding a plate in. Summer job of course, nasty one too. Dump the water, clean out the box, crawl in, grind out a nice area to plate, then weld in there.. lol (and mind the fresh air, dont wanna die in there). You better get some seriously premium steaks if you're gonna con a buddy into doing it.
