solar collector pipe size?
Old 03-17-11, 07:29 PM
i am going to have 2,3, or 4 solar colectors installed depending on what i need but i want to know what pipe size would that be or should i have them all on there own closed loop system with 3/4'' pipes?
Old 03-17-11, 07:46 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
If you are going to have them installed, then the installers will know what size pipe to use.
I'm moving your question to an appropriate forum. "Boilers" is not it.
[edit: on the other hand, I can't seem to find a 'solar' category ! So here it will stay until I do...]
Old 03-17-11, 08:16 PM
3/4" pipe is fine for most solar applications, unless you have a ton of panels.
Often 1/2" is more than enough
Old 03-18-11, 05:26 AM
What are they for? Space heating or domestic hot water?
Old 03-18-11, 08:35 AM
This would be the the one: Greening Your Home Power and Water Systems - DoItYourself.com Community Forums
Old 03-18-11, 08:59 AM
NJT's Avatar
NJT
NJT is offline
Yeah, I agree, but I see next to ZERO activity in that forum...
