ZONE VALVE Problem
Closed Thread
Old 04-03-11, 10:20 AM
starwalls's Avatar
ZONE VALVE Problem
Taco zone valve 555-102
My heat won't start unless I move the lever down a little bit then it runs all day then I have to do it again.
What is going on here????
Can anyone help me?
Old 04-03-11, 04:20 PM
Grady's Avatar
Received 25 Votes on 23 Posts
How many zone valves do you have & is this the only one acting up?
Old 04-04-11, 06:52 AM
starwalls's Avatar
I have two and yes this is the only one with a problem, I checked the wireing, and redid it so if there was a small break. If I put it manual, pull it down just a little it works. I did an oma test all is good. WHAT is the problem? Please can anyone help me with this???
Old 04-04-11, 10:30 AM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
If you are sure that the wiring is all good, then rather than mess around trying to figure out what is wrong, why not just replace the power head and be done with it?
Old 04-04-11, 11:24 AM
Grady's Avatar
Sounds like a bad end switch in the power head. I'm with Trooper in his suggestion of replacing the head. It's a 5 minute job.
Old 04-05-11, 04:59 AM
starwalls's Avatar
Thank you all for all your help on this matter, found the problem....Redid all the wireing all works good now, must have had a broken wire...
Old 04-07-11, 05:55 AM
starwalls's Avatar
Taco Zone valve
I have two taco zone valves. One has been acting up. I did find a broken wire. Is it right if when I checked to see if valve was working that the little arm goes down a bit? I always thought that it stays in one place up, and its the inside that moves???
Should I change this with the other one that seems to be working good, and if so to change I wait til it goes off then just remove???
Closed Thread
