Spirovent leaking after some work.
Old 04-18-11, 05:43 PM
Is it normal for the spirovent to to spit out air bubbles and water after opening the system.
I took my indirect Hwh apart to clean the coil. It is still dripping and bubbling after a few cycles
Old 04-18-11, 07:17 PM
I capped it for right now. Will there be enough room to take the head off. Not the joist about an inch above the vent
Old 04-18-11, 07:41 PM
I would think it was venting air from your pipes, like it was made to do.
I would take that cap off. But I am not a pro, just a home owner.
Old 04-18-11, 07:59 PM
All the air came out and it continued to drip for like 45 minutes before I capped it. Looks like I got another project in front of me
Old 04-18-11, 08:37 PM
you probably got some crud stuck in the head assembly. try removing it, you should be able to even with the joist up there. then try to clean it up a bit, maybe some vinegar or CLR. they are very expensive to replace so try to clean it up first. a new spirovent is probably about $130-$150, just for the part.
Old 04-18-11, 08:50 PM
I priced out the head for about $50 on line. I will get a new O ring and try to get it apart later on. I saw a pic on line and it looks close as for getting it of.
