recessed wall hydronic radiators.
Old 07-14-11, 01:23 PM
T
do they make recessed wall hydronic radiators that are not fan convectors and are still inside the wall between the studs? if so do you have a link to the product?
Old 07-14-11, 02:55 PM
G
Received 27 Upvotes on 26 Posts
What about the underfloor radiant hydronic systems? Google, and you'll find many links. Check with the manutacturers to see if they recommend for in-wall use.
Why are you adverse to an in-stud-mounted kickspace heater, with a fan, such as Beacon-Morris? They are effective and are sized to fit right into a 16" o.c. stud space.
Old 07-14-11, 04:14 PM
rbeck's Avatar
Received 65 Upvotes on 55 Posts
Burnham has cast iron radiant radiators which are recessed and covers are available.
http://www.usboiler.burnham.com/prod...literature.pdf
