is there a pressurized thermal storage tank that is collapsable?
Old 07-15-11, 05:19 PM
i am currently looking for a pressurized thermal storage tank that can actually be taken apart and re bolted together to fit through door ways. if you know a company that makes these since i want to use one in conjunction with a wood boiler.
Old 07-15-11, 07:14 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
I sorta doubt you will find what you are looking for.
I came across this guy's idea a while back. The tank is not pressurized, is homebuilt, and has coils of tubing inside to serve as a heat exchanger. Might be worth some thought?
Homemade Thermal Storage Tank
Old 07-16-11, 05:27 AM
You might also look at these guys
STSS CO INC Products
Old 07-16-11, 06:45 AM
GregH's Avatar
Super Moderator
Received 19 Votes on 19 Posts
Well there is something like that......sorta.
You buy a tank in pieces then have a ticketed pressure welder assemble it in place!
One thing you should know is that it it not permitted to have a wood fired boiler connected to a pressurized hydronic system.
The circulating pump should draw its water from an open vessel.
