zone valve orientation
Old 09-05-11, 09:22 AM
T
Hi everyone.
I'm replacing an old white rogers zone valve with a taco 571-2.
Due to space limitations I have to install the valve on a horizontal pipe.
The taco documentation shows the power head should be on the top side of the pipe in this application, which won't be easy for me in this location.
Question is,
Will the life of the valve be shortened if I install it with the power head on the side (3 or 9 o'clock position) of the pipe? I was thinking that I could tip the head up as much as possible to keep any water from getting in the power head in the event of a leak.
Thanks for any help.
Old 09-05-11, 10:01 AM
lawrosa's Avatar
Super Moderator
Received 78 Upvotes on 70 Posts
HI,
Its a two position head placement.
The body can be placed in any position. Upside down if thats your fancy.....
http://www.taco-hvac.com/uploads/Fil...102-111new.pdf
Mike NJ
Old 09-05-11, 11:20 AM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
That's a different zone valve though Mike...
This is the one he's installing:
http://www.taco-hvac.com/uploads/FileLibrary/100-3.pdf
Why not use a Honeywell valve? Lower profile, would probably fit.
Which WR valve are you replacing? Four wires?
Old 09-05-11, 11:27 AM
T
Yes it's a four wire WR valve. Pretty much the same as a honeywell V8043 E 1012.
The reason that I want to use the taco valve is that I already have 3 of them. Got a really good deal on them. Didn't see that there could be an install problem till I looked at the documentation.
Old 09-05-11, 11:36 AM
lawrosa's Avatar
Super Moderator
Trooper I see the mounting position but IMO what would be the difference if on a horizontal with a 45 degree twist?
I see no internal mechanisms that would warrant this. Expecept for possible water hammer?
But who knows......
Mike NJ
Old 09-05-11, 11:50 AM
rbeck's Avatar
Received 61 Upvotes on 51 Posts
The only problem I can see is the internal structure of the valve. There is a low slot on the inlet and a high slot on the discharge which makes it very easy to pass air through it. If it is turned it would make it harder to pass air. Is it enough to be a problem?
