Taco Variable speed Delta-T Pump
Old 09-05-11, 07:32 PM
What can you guys tell me about a 008 VS Delta-T pump?
I am planing on zoning my radiant floor with circ. pumps, three of them. One manifold for the garage, and two manifolds for house. My primary pump is a Taco 00 3 speed. And was going to use three more 00 3 speed pumps on the secondary loop. Do you think the VS Delta-T pumps would be better, then the 00 3speed ? The cost would be a lot more. But would it be worth it?
http://i308.photobucket.com/albums/k...2475/Plans.jpg
Old 09-07-11, 05:56 PM
I can tell you that I would strive to not use either the 00 3-speed or the 008 VSdT. Go with an ECM smart pump like Grundfos Alpha or Wilo ECO and use zone valves.
The 008, even in VS dT application, is a honking big pump, electricity-wise.
If you have actually designed the system for a constant dT at all loads, it might be a decent application, but that is rarely the case.
Old 09-08-11, 07:03 PM
The Bumble Bee should be out soon. They look to be pretty nice pumps, they have the ability to do more than the Grundfos Alpha.
Old 09-08-11, 07:42 PM
Who is making the Bumble Bee Pump ? And what is it?
Old 09-08-11, 08:27 PM
It is Taco's entry into the high-efficiency ECM pump market. I waited a long time, then got tired of waiting and went with Grundfos Alpha. Very happy with the Alphas. (Speaking here as a longtime Taco user and fan....)
Old 09-09-11, 08:15 PM
I plained on zoning w/pumps, so if I go with zone valves what brand or model should I use ? They will be 1" valves.
Old 09-11-11, 05:17 PM
These are good
Taco-Hvac: Zone Sentry® Zone Valve
also Belimo makes very nice ones, but can be hard to get in some places.
