Baseboard heating in condo won't turn off!
Old 10-17-11, 11:13 PM
Hello heating experts,
I'm having a problem with the heating system in the condo I own and occupy. I would love to get some advice on how to proceed to fix this problem. Here are some details:
1. I live in a 1-bedroom garden-level condo built in 1981. A common boiler provides hot water to baseboards in the 8 condo units in the building.
2. In my condo, there is one faucet-style valve on the baseboard near the entrance on the condo and one faucet-style valve on the baseboard in the bathroom.
3. I have one Lux 1000 programmable thermostat with 2 AA batteries installed on the wall in the kitchen. I see two wires (one red and one olive green) coming from the wall to the box.
4. If I leave the thermostat set to "HEAT" but set the temperature (way) below the room temperature, the heat comes on and stays on.
5. If I turn the thermostat to "OFF" and manually close the valve on the baseboard by the front door, the heat stops.
6. If I let the baseboards cool and manually open the valve leaving the thermostat "OFF", there is no heat.
7. As soon as I turn the thermostat switch from "OFF" to "HEAT", even if the thermostat temperature is set 10-20 degrees below the room temperature, the heat comes on and stays on until I repeat step 5.
8. I hear the thermostat click whenever I turn it on or off or if the temperature setting goes above or below the room temperature value.
9. I've lived in the condo since Sep 2004 and haven't had a problem with the heating system until this problem started a couple of days ago.
Thank you in advance for any advice!
Old 10-17-11, 11:28 PM
lawrosa's Avatar
Super Moderator
Received 19 Votes on 17 Posts
I think its the t stat that is shot or wired incorrectly.
If you disconnect the two wires from the t stat touch them toghther. Does yor heat work? Disconnect the wires, does the heat go off? If so get a new t stat.
Also was that t sat always there? If its new possibly its possibly wired incorrectly.
Mike NJ
Old 10-18-11, 09:39 PM
NJT's Avatar
NJT
NJT is offline
Received 2 Votes on 2 Posts
See the thread " CONFUSED " ... I wonder if you are faced with the same issue? A reverse acting thermostat. In this case the thermostat was listed as a COOLING thermostat and the contacts CLOSED on temperature rise.
What happens when you turn the thermostat all the way UP ? Heat goes off ?
What was the make/model of the thermostat which you replaced? or maybe I'M confused? and you have always had that thermostat? (what Mike asked)
Old 10-19-11, 01:48 AM
Thank you for the replies. The t-stat had been functioning properly for several years up until last week. There have been no wiring changes.
I pulled the t-stat and the resistance checked good (short when switched on, open when off). I checked the batteries, blew the dust off, cleaned the terminals, and pushed the "HW RESET" button. Then I re-programmed the t-stat.
Then I shorted the two wires from the wall a few times and noticed the heat would turn on when they were shorted and turned off when they were separated.
I put the t-stat back together and the system tested good. I guess something was stuck having sit all summer without turning on? I don't know for sure but things seem to work OK now.
Many thanks again for the replies!
