Bg circulating pump
Old 11-01-11, 07:23 PM
Question Bg circulating pump
I just installed a new circulating pump in my home 2 weeks ago on my boiler&it crapped out on me I have110 volts ,to the pump,so I think its shot!Are these pumps very durable?Thank you!Jim
Old 11-01-11, 07:31 PM
rbeck's Avatar
Received 2 Votes on 2 Posts
They have always been good operating pumps with many years of operation.
Old 11-01-11, 07:36 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
"shot" "crapped out" ...
Whattaya mean, the motor isn't running?
Old 11-02-11, 02:06 PM
It was making a lot of noise before it stopped working,do you know what would cause that motor to die or perhaps was it defective?
Old 11-02-11, 03:42 PM
NJT's Avatar
NJT
NJT is offline
What kind of noise? Was it like a 'hammering' ? Is so, perhaps the 'coupler' gave out?
If you are somewhat handy and if this is the problem, you probably could fix that yourself...
Was it more like a 'grinding' noise?
Was there oil in the bearing assembly?
Old 11-02-11, 05:16 PM
Received 8 Votes on 8 Posts
You haven't told us the model no. of the pump. In addition to 3-piece, dry-rotor pumps, which B&G is most noted for, I think they also sell wet-rotor pumps. A photo would be helpful.
Who installed the pump? If a serviceman, call him. In any case, a 2-week-old pump will still be under warranty. Did the pump work OK initially?
Depending upon the type of pumps, there are several ways a new pump could shoot craps, e.g., running it dry and mounting it in the wrong orientation.
