Continuous or Intermittently running circulator pump, which is best
Old 12-12-11, 08:49 PM
My house has 3 zones using taco-571 valves. There is one circulator pump that runs on 110v. It is running continuously year round unless I disconnect the two wires on the furnace control panels. Pulling the two wire going to 24v terminals shuts off pump.
Each valve is controlled by its own thermostat and I was wondering if that valve is suppose to run all the time. Over the summer I disconnected the two wires letting it get power to turn it off. Does it matter which way I re-connect them (I forget which wire went to which terminal..thin 24v wiring)
I swear my oil bill dropped over the summer and my basement was cooler just by disconnecting that circ pump. Only thing I can think of is that the zoning was a retrofit and they original Owens never wired it up properly.
Old 12-13-11, 09:11 AM
Hello,
Doesn't sound correct at all.
Hard to follow the set-up.
Please try and take some clear large picture from different angles.
Peter
Old 12-13-11, 11:50 AM
Received 2 Votes on 2 Posts
Constant circulation for 3 zones in a home? I'm not a pro, but even to me that doesn't sound right. Most systems only run the circulator when there is a call for heat.
