Boiler won't automatically kick in (sometimes)
Hoping to get some advise...I am guessing something electrical. The Utica boiler to our radiator system "sometimes" will not start automatically. I have to go downstairs and hit the reset button on the gray Honeywell box. A scary thought with the winter coming here in New England and the pipes freezing if we're away. I probably did not give enough info but could someone let me know or ask me for specifics? Thanks...Tom
Freet, I'm guessing by your description that this is an OIL fired system? and the gray box you are pushing the reset button on is attached to the burner, above the motor?
If so, then you need to call a technician to have the boiler cleaned, and the burner serviced.
Oil fired equipment should be serviced yearly... new nozzle, electrodes adjusted, combustion tested, internal brushing and vacuuming of the combustion chamber and the heat exchanger, oil filters changed, etc...
If you keep pushing the button, and the burner doesn't fire, you will get unburned oil building up in the boiler... and this could be dangerous. If you DO do this, please tell the technician you have done so!
Do NOT let this go, because it will get worse... and will completely fail to restart at some point... when it is 20 below, in a blizzard, on Christmas Eve... ain't that always the way?
