burnham in4 gas fired steam boiler electric question
Old 12-18-11, 01:41 PM
Hi all, I have a Burnham IN4 gas fired steam boiler, does this have a blower that is power by electricity? what is the electricity actually powering on? Thanks for your time, Sean
Old 12-18-11, 02:42 PM
NJT's Avatar
NJT
NJT is offline
Received 4 Votes on 3 Posts
Hi Sean, I'm really not clear on your question... can you tell us why you are asking? and a little more info?
If you just want to know what runs on electricity... well, the controls do, the gas valve does, if you have a vent damper, that does...
Old 12-18-11, 04:26 PM
rbeck's Avatar
Received 12 Votes on 9 Posts
The model number you mentioned does not have a fan. A fan would be on an INPV4 the PV standing for power vent. The fan and circulator runs on 120v everything else runs on 24vac.
Old 12-19-11, 05:50 PM
Thank you guys, my real question is about using the furnace with a generator in case of power failure. It was suggested to go with a 6 circuit transfer switch to the main. While that makes sense and sounds good, it's about $800 to install.
Is it possible to get the furnace going on generator another way?
Thanks again,]
Sean
Old 12-19-11, 07:07 PM
NJT's Avatar
NJT
NJT is offline
Hi Sean, yes, there's always another way... but I would recommend that you ask this question over in the electrical forum. There are folks there that are better prepared to answer this type of question.
