Taco 007-F5-1IFC Cartridge Circulator stuck open?
Old 01-13-12, 07:09 AM
It seems that the flow control valve (Taco 007-F5-1IFC Cartridge Circulator) for one of my two zones gets stuck open and then I have the zone too hot due to runaway heat. Is this something that can be repaired or will the whole unit need to be replaced?
Old 01-13-12, 09:23 AM
G
Yes, it can be replaced: 0010-025RP - Taco 0010-025RP - IFC Replacement Kit for 005, 007, 00R Taco Pumps (Google is your friend.)
If you don't have valving around the pump, you may have to drain the system to access the pump IFC. Have the replacement part available before tearing into the pump. You might want to order a replacement rotor cartridge too - in case your impeller is chewed up. If it's OK, it will be good to have a spare on hand.
