Conflicting information.
Old 01-17-12, 02:19 PM
H
I need to replace the gas valve on my Hydro-Therm HC-E 125. The part number for the valve is VR8200H1129. This is an obsolete part. I looked online and found that VR8200A2132 replaces H1129 according to a couple different sites. When I called my local heating supply company they told me the replacement part is VR8300A3500. Can anyone shed some light on this situation? Thanks.
Old 01-17-12, 02:56 PM
G
Received 28 Upvotes on 27 Posts
You don't tell us the brand of the gas valve. But, if the replacement valve has the same size pipe connections, the same end-to-end dimensions, the same pilot/ignition arrangement (e.g, standing pilot, etc.), the same operating voltage, and a Btu/hr rating at least as large as the boiler's input rating, it should be OK. For example, my original gas valve was a very old Honeywell, and I replaced it with a Robertshaw model - totally different exterior appearance.
What is wrong with your existing gas valve?
Old 01-17-12, 03:20 PM
lawrosa's Avatar
Super Moderator
Received 84 Upvotes on 76 Posts
May have messed up in your search.
I get this consistantly when searching. Replacement # VR8200H1251
Patriot Supply - VR8200H1251
Honeywell Gas Valve VR8200H1251
Here is your manual I think.
http://search.yahoo.com/r/_ylt=A0oG7...litFileID=1550
Mike NJ
