should i remove all my ductwork to replace them with zoned fan coils?
Old 01-19-12, 12:13 AM
T
should i remove all my duct work to replace them with zoned fan coils? the reason i am wandering this is because i am tired of cold spots and want to have radiator quality heat that's even. i will be going with hydronic heat as the base for my system with a large thermal storage tank and wood, pellet and gas or electric boilers. also i may keep my duct work and use a hydronic air handler for the house central heat. i would like opinions on this. so the two options are central hydronic forced air with cooling or have each room with their own in wall heating/cooling fan coils. here is some links to the hydronic air handler and the fan coils.
Lennox CBWMV Variable Speed Hydronic Air Handler | Lennox Residential
http://www.turbonicsinc.com/TURBO-AIRE-BROCHURE.pdf
Old 01-19-12, 11:55 AM
P
If you are considering running water to each room for hot air, then is fin tube basboard also an option?
Peter
Old 01-19-12, 02:19 PM
T
not really since i want to keep my wood work and do not want to remove it for baseboards.
Old 01-19-12, 03:06 PM
P
IMO separate room control is always desireable.
Peter
Old 01-19-12, 04:27 PM
T
my old duct work is asbestos and missing old parts. so i am deciding on weather to abandon them or have new duct work put in.
