air eliminator for hydronic system
Old 03-12-12, 10:53 AM
_
i tried to search for the answer to question on this forum, but didn't find a exactly what i'm looking for.
it seems that there are multiple designs for air removal devices for closed loop hydronic system (looking at pex supply web site):
Air Eliminators , Taco Air Scoops , Spirovent Air Eliminator - PexSupply.com
do all of them perform the same function? can either of them be used in residential hydronic systems?
is there specific type/model that is preferred on this board?
thanks!
Old 03-12-12, 01:06 PM
lawrosa's Avatar
Super Moderator
Received 77 Votes on 69 Posts
They all try to perform the same job to remove trapped air. Some are better then others. Some are just a wing inside to disturb the air bubble and deflect it up to the top where the air vent releases it.
http://www.pexsupply.com/Taco-400-4-1-8-Hy-Vent
O
thers are scrubber types that have a type of coil spring inside to separate the air better. They have air vents attached to them also.
A lot of older installs don't have the air scoops and just have air vents at high points in the system to purge the air out.
http://www.pexsupply.com/Air-Valves-300000
ike NJ
Old 03-12-12, 02:28 PM
NJT's Avatar
NJT
NJT is offline
Received 7 Votes on 5 Posts
One of our esteemed members recently brought up a good point about the Taco 'Vortech' unit. Since the air vent screws down into a 'well' on top, they can leak and corrode for a long time without being detected.
I think either the Spirovent or the Taco 4900 would be my choices.
Old 03-12-12, 07:01 PM
R
Received 3 Votes on 3 Posts
Interesting. I'll have to keep an eye on that. I have a Vortech unit on my home system. Fortunately, it's mounted only about waist high, so it's easy to view the top.
A major advertised benefit of the Vortech (aside from removing air quicker than a conventional air separator) is that you don't need a minimum pipe run into it nor out of it, which of course is useful in tight quarters. That is, in fact, a big reason why I chose it.
Old 03-13-12, 04:46 PM
_
guys, thank you for your replies.
one more question. if a boiler has 1-1/4" water connections and hydronic system has 3/4" pipes all around, I assume things like air eliminator supposed to be sized to match water connection of the boiler? does it matter at all?
Old 03-14-12, 07:29 AM
G
Received 20 Votes on 20 Posts
Doesn't matter - except either way, you will need to tee it down to the size of the air eliminator connection, so starting from 3/4" would be easier.
I assume you have a bladder-type expansion tank, as opposed to a conventional steel tank. With the conventional tank, no air eliminator should be installed - it will cause the tank to become waterlogged.
