NTI Legacy 150 firing issue
Old 04-23-12, 12:20 PM
Hi
I have a 2001 NTI Legacy 150 boiler. I recently had to change the ignitor and in turn the boiler worked fine for a week. Then it stopped working.
I went through a troubleshooting process with NTI and discovered that the Gas Valve Harness plug was not putting out 24 VDC and in turn needed to be replaced. I just replaced & tested that yesterday and it still doesn't fire up.
I have tested the MV1 and I have 24V AC.
I tested the W and I have ONLY 11.3 VAC which is supposed to be 24VAC
Gas is flowing and the gas valve is clicking on & off along with the ignitor glowing red.
http://www.nythermal.com/pdfs/Trinit...cFlowChart.pdf.
The NTI techs are now baffled except for the W wire (fenwal)
Please help
Alan
Old 04-25-12, 07:06 PM
Are you getting any error codes from the fenwall ?
