ERIE Zone Valve not closing all the way
Old 07-03-12, 10:21 AM
D
Is it possible to replace the return spring in an older ERIE 465B307-GA1 valve? It appears the spring is not able to fully close the valve. If I turn up the heat the valve opens, and when I turn the heat down it partially closes (80%). I am able to take the cover off and push on the actuator(?) (arm that connects to the motor) to close it fully. Would WD40 to clean off the spring and then a lubricant after help or could the spring just be getting too old to push back? The part is from 1996.
Old 07-07-12, 06:26 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
I have cleaned the spring on Erie valves with WD40 and a toothbrush sized wire brush before and it would then fully close.
If you can locate a replacement, they are not very expensive.
Old 07-07-12, 06:18 PM
G
Received 11 Votes on 11 Posts
I would replace it......................
Old 07-09-12, 06:21 AM
D
Thanks for the replies, I would replace it by my skills are somewhat limited. I found a plumber it was looking like around $450 which included recharging the system. If I can get away with replacing the spring that would be the most cost effective.
Houston204, did you pull the spring off the valve to clean it? Did you need a special tool to get it off and on? I was even thinking of installing a second pull spring to help out with closing, attach it to the actuator and then too the joist leaving the lid off of course....
Old 07-14-12, 10:34 PM
Houston204's Avatar
Solidyne Corporation
The spring closed, power open Erie zone valves that I work with have a small black release button to remove the actuator.
Refilling the loop would not be required to replace the actuator.
Cleaning it may prove to be a regular chore untill replacement occurs.
