Making a simple warm weather shut down for an oil fired steam boiler
Received 0 Votes
Would like to place a simple warm weather shutdown switch in line with the cable from the thermostat within the boiler room for a small commercial oil fired steam boiler.
We can easily install a sensor outdoors in the vicinity of the boiler.
Thought of using a klixon switch, an aquastat and things like that. Surely someone's already done this.... what works well?
I was going to suggest the temperature controller that I used, the Ranco one, for the oil heater. But then I started thinking about whether or not it would be a good idea to leave a relay energized the entire heating season.
I would want something with a 'latching' relay in it, like thermostats use. They typically don't hold the coil voltage, it's just a quick pulse to latch, and another to unlatch.
Maybe you can use a cheapo thermostat if you can mount it outdoors in such a way that the elements won't get to it?
Or even a simple non-electric model?
I have a "constant circulation" hydronic heat system that utilizes a Honeywell T675A Remote Bulb Commercial Temp. Control for essentially the same purpose - to shut off the heat (in my case, the heat circulator) during warm weather (i.e., the switch breaks on "temperature rise"). The circulator runs 24/7 during the winter. The control has to be at least 20 years-old and I haven't had a problem with it.
Just something to consider...
