Can I replace iron radiator supply piping with PEX
Old 11-16-12, 12:49 PM
W
I wish to minimize the overhead iron piping to the radiators in my basement area apartment for appearance and headroom purposes. The system is on its own circulator pump circuit. Can i replace trhe iron piping with PEX thread through the ceiling joists?
Old 11-16-12, 02:09 PM
G
Received 13 Votes on 13 Posts
Ordinary PEX can't be used for hot water heating - you need the type with an oxygen barrier, which might not be available at the home centers. PEX isn't threaded - you will need threaded adapters.
You might want to wait until spring in case you run into problems.
Old 11-16-12, 03:48 PM
NJT's Avatar
NJT
NJT is offline
Received 4 Votes on 3 Posts
Since you have used the word " ...apartment... " we have to ask:
Are you the OWNER of the property?
And I have to concur with gilmorrie that this is NOT a project you want to start now. Major modifications to heating systems are SPRING SUMMER FALL work, NOT Winter!
