Weil-McClain pump Q's
Old 11-27-12, 06:43 PM
Hello, I have only had one other q on here so I think Im still kinda a newbie... we had a new WM boiler installed 2 years ago, It is 9000 btu larger than the the Burnham that we replaced. Our issue is that this WM unit doesnt seem to keep our house a constant temp as our Burhnam did. The only differance that I can tell is that the pump on our WM only runs when it is doing a burn. Our Burhnam pump ran most of the time whether it was doing a burn or just sitting waiting on a call for heat. The pump was either temp or psi switched, I dont know. The Burhnam unit was 50+ years old and only had the pump replaced once. Now as soon as the thermostat reaches temp and ****s off the boiler the pump runs for just a few minutes and shuts off, we can tell a differance right away. Our installer said that this was not possible for the pump to run like it did on the Burhnam. Is this true?
FYI: Single zone (I guess) We only have 1 thermostat
Thanks in advance...
Old 11-27-12, 08:16 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
If he was the installer, didn't he also remove the old system?
Perhaps someone retro-fitted some controls over the years?
There were plenty of systems that were CONSTANT circulation, pump ran 24/7 all winter. Maybe that's what you had?
What is the model of the new boiler?
Old 11-27-12, 09:13 PM
The 'kid' that put it in is only 22 yrs old...not saying he doesnt know what he's doing but he didnt install the old system. I didnt hire him, I simply inherited it and its problems... The installer is more of a parts changer than a diagnostic, trouble-shooter. Thats why he hasnt been called back to work on it since it was installed.
Model #: Weil Mclain 381357337 77,000 BTU
We went from the Burhnam 68,000 BTU.... Now I know that the pump did not run 24/7 but I do know that the psi and temp was WAY down before it shut off.
When the burner started it took a little time before the pump came on....like 2-3 min but once it did it stayed on till it had cooled down alot.
Thats what I would like for this one to do.
Old 11-28-12, 04:09 PM
NJT's Avatar
NJT
NJT is offline
I don't think that's the model name/number?
Is there anything else?
