HELP DIAGNOSE. . .TRANE XL80 has not heat
Old 12-07-12, 03:27 AM
D
I replaced the circuit board and ignitor 1 month ago. This morning I have no heat and the FLASH CODE says: GREEN 1 Flash "STANDBY CALL FOR COOL". i DO HAVE GAS SUPPLY. i'M HEATING THE KITCHEN WITH GAS RANGE.
Old 12-07-12, 03:39 AM
D
I have tried to reset by turning the power off for 10 minutes with no luck. . .
Old 12-07-12, 03:44 AM
D
homeowner for this thread
I have tried to fix by turning off the power for 10 minutes without luck
Old 12-07-12, 04:05 AM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
Shut off your gas stove!!!! Are you trying to kill yourself?!
Slow flash (what you call a 1 flash) is normal operation/ standby. A fast flash is call for heat. It sounds like your thermostat is not calling for heat. Remove the thermostat and wire nut together the wires attached to R and W. DOes the furnace run now? IF so, this indicates you need a new thermostat. If not then you should try jumpering R and W on the control board of the furnace.
Old 12-07-12, 04:43 AM
D
owner
THANKS for quick reply! I have shut down the gas range. I connected the red and white thermostat wires and now I get code for "1ST Stage Pressure Switch Stuck Open/Inducer Error" I tapped on it a couple times and tried again without any luck.
Old 12-07-12, 05:06 AM
D
owner
I truely appreciate the help! I guess it's obvious now, I will have to replace that pressure switch and thermostat
Old 12-07-12, 05:44 AM
hvactechfw's Avatar
95% of the time it is NOT the pressure switch. Check the flue for obstructions. Check the port that the pressure switch goes to for debris. Ream it out with a small drill bit.
Old 12-07-12, 07:13 AM
D
owner
OK, Thanks. I'll go to roof and check for a birds nest
Old 12-07-12, 01:31 PM
D
I thanked God today for you "HVACTECHFW". I'm thankful for unselfish folks out there willing to help an old man keep heat in the house while living on a budget.
You were correct, Sir. it was not the Pressure switch. I tracked it to the thermostat. I'm fixed. THANK YOU!
