Connecting Circulator Pump
Old 12-28-12, 08:09 PM
Ihave read these forums and followed alot of great advice on other topics. Now I am I have a problem, because I failed to write it down....
Recently the flanges on the circulator pump cracked and water was spitting everywhere. So I called in the local plumber to get it fixed (Not fond about playing around with a boiler)... anyway, to replace the pump and flanges his quote was $900. I remember seeing the costs of a new circulator online and thought his quote was really high.. Anyway. I decided to do it on my own....
Picked up a Bell & Gossett P58671 and the flanges... replaced everything. Filled the boiler back up with water and then I went to wire the pump to a honeywell R8182D, this is where I want to smack myself. I forgot how the wires reconnect...
The pump has a white wire and a black wire. I am assuming that the black wire is the "neutral" wire but I dont know where either one goes... Does the bacl wire connect to the b2/c2 or the c1
I am just worried about wiring it wrong and "poof" circulator is fried.
If anyone can help I would truly appreciate it, as it is 20 degrees outside and the house is starting to really cold. Snow on the way too. LOL
Old 12-28-12, 08:14 PM
Received 605 Votes on 570 Posts
Normally you remove the wire from the pump so that you have a cable with a white and black wire.
Did you pull the wire out of the control box ?
P.S. In electric.........white is ALWAYS neutral.
Old 12-28-12, 08:19 PM
C1 is black
B2 C2 is white
I pulled the wire from the pump out.. they were white and black.
I originally took the wires off from the honeywell so that I can get the pump off.
That is where my problem is.. I have the white and black from the pump and do not know where I put them on the honeywell
Thanks for the tip on white wire being neutral
Old 12-28-12, 08:23 PM
Thank You so very much for the help!!!
Old 12-28-12, 08:47 PM
Anytime.....Matt from NJ
