Heater
Old 12-30-12, 05:31 PM
Heater
Hi my ist time on. Woke up to no heat. Its giving me the code of pressure switch stuck open. Took hose off of draft inducer & everything got hot. Draft inducer is not spinning.
Old 12-30-12, 05:34 PM
Needs advice. Please help
Old 12-30-12, 06:12 PM
Received 8 Votes on 8 Posts
Is this a hot-water boiler? Model number?
This will be, I fear, a computer-controlled system - may be beyond DIY.
Old 12-30-12, 06:17 PM
Received 517 Votes on 487 Posts
.......everything got hot Like what...for example ?
If you disconnect the hose off the draft inducer nothing can get hot.
Old 12-30-12, 06:26 PM
Heater
Meant to say i took it off & sucked on the hose
Old 12-30-12, 06:29 PM
Heater
Its a coleman forced air heater
Old 12-30-12, 07:08 PM
If the draft inducer is not spinning then that's where you need to start your troubleshooting.
You'll need an AC meter to check it out. Most of those motors run on 120 volts AC. You'll need to check on the board where it's connected to see if you have power.
Old 12-30-12, 08:26 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
Yeah... and you are trying to poison someone with Carbon Monoxide poisoning.
Without the draft inducer running and you 'tricking' the thing into running, you are likely have exhaust from the boiler pouring into the home.
Please do NOT kill yourself or your family by continuing to run that boiler in this manner! Either repair it properly or call a technician who can.
