Removing hot water baseboard heater
Old 12-31-12, 02:55 PM
O
I want to remove a baseboard heat section from a small bathroom. The bath has no exterior walls and little floor space so I would like to remove it and maybe replace with radiant floor in the future. It seems a simple matter of draining the zone, cut out radiator and reconnect. I am wondering if: use PEX and shark bite connector are ok and after I am done how to purge air. (It is currently the last heater before return to boiler and the bleeder valve is located right before)
Old 12-31-12, 03:06 PM
lawrosa's Avatar
Super Moderator
Received 77 Votes on 69 Posts
Your plan sounds OK.... I personally do not like shark bites... Additionally if you use pex you need the kind with the oxygen barrier....
Not a fan....
What type of baseboard??? Cast, copper?....
Old 12-31-12, 03:20 PM
O
Thanks for getting back to me. It is the cooper and fin type of baseboard. What "color" is the oxygen barrier PEX? White? I would prefer to use copper but thought the PEX would require less draining than using copper. How do I purge the air if the valve is located before the heater? Won't there be four feet of air in the pipe when I am finished? (that sounds sort of silly and unclear but can't think of how else to put is)
Should probably add that the house was on well water for years with loads of repaired leaks and a majority of "M" copper, thus will probably be switching just about every thing out to PEX (per plumbers who have been in to bid various projects)
Old 12-31-12, 03:43 PM
lawrosa's Avatar
Super Moderator
The air should purge from an air seperator or AAV that is at or near the boiler. This will occur after you get the main air out from a manual purge.
Old 12-31-12, 04:28 PM
G
Received 20 Votes on 20 Posts
Just to satisfy my curiosity, could you post some photos of your situation? I'm having a hard time visualizing how removing a baseboard would increase floor space much - and then deal with all the complications.
Old 12-31-12, 05:23 PM
F
Received 36 Votes on 28 Posts
In addition, depending on how it is piped it is quite possible you can simply cap off the connections without worrying about anything else.
Old 01-02-13, 04:54 AM
N
Received 20 Votes on 18 Posts
This was my first thought when I read the OP.
By the sounds of it, the OP has the finned baseboards connected in series. If the baseboard was connected like mine (parrallel to a main loop), Cut --> Cap --> done.
