Oil burner with 2 zone radiant heat
Old 01-08-13, 04:52 PM
I have an oil burner with 2 zone heat. Zone 1 works great. Zone 2 the problem.
Change out the circulating pump and the aquatstat for that zone. When I set the thermostat to call for heat, circulating runs but the burner doen't fire. Look like another aquastat for zone 1 and zone 2 wires into it. What am I doing wrong?
Old 01-08-13, 05:10 PM
NJT's Avatar
NJT
NJT is offline
Received 7 Votes on 5 Posts
What do you mean?
What model is this 'aquastat' you changed?
Old 01-08-13, 05:36 PM
A Honeywell RA89A (zone 2 ) which I changed out. Honeywell L8124 (zone 1) did not change.
Zone 1 works well. Zone 2 , circulating pumps runs but boiler does not not fire.
Old 01-08-13, 06:45 PM
NJT's Avatar
NJT
NJT is offline
Ok, the RA89A is not an aquastat, it is a RELAY.
What does this mean?
Is it possible for you to take some pictures? I need to be able to see how this thing is wired... cell phone pics probably won't do.
Old 01-08-13, 07:04 PM
How do I attach a photo to this forum?
Old 01-08-13, 07:13 PM
NJT's Avatar
NJT
NJT is offline
You won't see the icon if you use the "quick reply" window...
If you click on "+Reply to Thread" you will see an icon that looks a little like a tree in a picture frame.
Click that and you should get a box to upload from...
Old 01-08-13, 07:23 PM
NJT's Avatar
NJT
NJT is offline
Let me ask you a few more questions...
Have you lived with this system for some time and know for a fact that it did in the past fire the boiler when zone 2 called for heat?
The RA89A is what is called a SINGLE POLE relay. I presume that your thermostat is wired to terminals " T T " ?
and the circulator pump is wired to terminals 2 and 4,
and the 120 VAC line coming into the relay is wired to terminals 2 and 1 (black on 1, white on 2)
and there is a jumper bar between terminals 1 and 3 ?
Is this all correct?
Is the relay for zone 1 a different model? perhaps an RA832A
and if so, are the " X X " terminals in this relay wired to the " T TV " terminals in the 8124 ?
another aquastat RELAY for zone 1 and zone 2 wires into it.
Can you tell me what terminals these wires are connected to in both relays?
