20 degrees difference between floors
Old 01-22-13, 05:27 AM
My first floor is 20 degrees colder than the 2nd floor ? How can I tell if my circulation pump is working?
Old 01-22-13, 05:32 AM
Please elaborate on your system.
Type of boiler, size, type of rads etc.
You have to provide more info so we can help narrow things down by elimintating some of the other varaibles.
It might be as simple as an air trap somewhere, have you bleed all the rads ?
Low pressure can affect flow on higher floor levels, have you checked your pressure in the boiler ?
Old 01-22-13, 05:42 AM
pressure gauge says 14 lbs? which is where I have always kept it... I don't know what type of boiler it is rad vary throughout the house. I bleed it regularly so i don't think there is air also the first floor is the colder of the 2?
Old 01-22-13, 06:59 AM
lawrosa's Avatar
Super Moderator
Received 19 Votes on 17 Posts
You should be able to hear the pump.. You can test for voltage with a multi meter...
Even though your gauge reads 14 psi, it may be broke. Does it move off of 14psi when the boiler gets hot?
Read the sticky at the top of this forum, How to verify a boiler pressure gauge".
