No getting hot water
Old 02-26-13, 01:35 PM
F
Unhappy Not getting hot water
I have an American Standard hot water/stream boiler model#1BN-J1, boiler #G-403
Iím having trouble with the hot water. I open the faucet and the water comes out lukewarm for a short period of time and goes cold quickly.
I replaced the mixing valve, flush out the boiler and reset everything back to normal. I still get no hot water at the faucet. The water might get lukewarm and goes cold quickly. Any help or advice will be a greatly appreciated. Thank you Ed.
Old 02-26-13, 03:13 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
Ed, did you mean to type STEAM ( not stReam ) ?
How is the water level in the boiler?
G
Received 2 Votes on 2 Posts
The first thing I would do is try to choke the incoming water close to inlet of dom. coil Try this while running hot water somewhere at a decent clip.City water here is better then 150psi.If you got well water another easy thing to try is a product like boil a coil,dom.coil stays in place.Next would be a acid flush which you should hire a pro to do,which I'am sure would rather replace the whole coil or boiler Yes first what Trooper says.
Old 02-27-13, 11:21 AM
F
Yes I mint to type steam not (Stream)
Ií am going to bypass the mixing valve to see if thatís theproblem.
Iíll post my finding as soon as I get it done. Thanks guysgreat place for info.
Old 02-27-13, 11:39 AM
NJT's Avatar
NJT
NJT is offline
Ed, you didn't answer my other question:
Old 02-28-13, 07:59 PM
F
Sorry, NJ Trooper, the water level is fine, its where it should be, answerto 2[SUP]nd[/SUP] ?
This morning I Soldered a piece of copper pipe with aball valve so I can shut and open it when needed. I bypass the mixing valve,Once I completed my project I opened the valve and I started getting hot waterat faucets; so the problem lies with the mixing valve. It must be defected,even thought its new, only a week old. Now Iíam going to replace the valveagain and see what happen then. Thank you
Old 02-28-13, 08:02 PM
NJT's Avatar
NJT
NJT is offline
One needs to be very careful to flush out the water lines when installing new valves. Sometimes the smallest piece of 'crud' that gets inside a new valve can mess it all up.
Can you remove the 'guts' from the new valve and see if there's anything stuck inside?
