Q regarding draining condensate from condensing boiler
Old 03-05-13, 02:21 PM
_
What are the options for discharging the condensate beside having a drain pipe connected to a drain?
I do not have a drain in my basement, but I do have a port on my big drain pipe where washer drains to. The port is about 3 feet above the floor level. So an option would be to have a sump pump taking care of it, but it seems a bit of an overkill, plus the port is far away from possible boiler location.
Are there any other options? What is the typical amount of condensate say per day/week?
Old 03-05-13, 03:10 PM
NJT's Avatar
NJT
NJT is offline
You should also plan on a neutralizer. Can be purchased, or make your own from PVC pipe and fittings and use marble chips from the garden center.
