Circ Pump Installation
Old 03-06-13, 07:45 AM
roadking's Avatar
I have a TACO Series 1611 pump circulating HW (180 degree) through a reheat coil. The pump is mounted in a vertical position. (motor in the UP position). I am having a premature bearing and seal failure. I believe the motor should be in a horizontal position. Am I right, and could this be the reason for seal/bearing failure?
Thanks
Old 03-06-13, 08:06 AM
G
Received 10 Votes on 10 Posts
Here are the installation instructions. You can call Taco for additional info.
http://s3.pexsupply.com/product_files/1600Install3.pdf
Old 03-06-13, 08:34 AM
roadking's Avatar
That's what I thought, THANKS!
