96% efficient boiler vent termination
Old 04-05-13, 02:23 PM
I'm at the end of my installation of my Rinnai E110c combi-boiler.
I've read through the book and they list all the clearances from windows, doors etc. What they don't mention is if there has to be a certain distance of protrusion from the house structure itself.
Is there any minimum?
Old 04-05-13, 02:44 PM
I'm exiting with a two pipe system.
I call the vertical risers " candy canes " because of the shape. High enough to be above the snow and far enough apart not to feed each other.
Can they be against the house ( so if you looked at it while looking at the house, you'd see two up side down j's) or should they be pointing away towards the yard? Does it matter?
Old 04-05-13, 02:59 PM
lawrosa's Avatar
Super Moderator
Received 3 Votes on 3 Posts
That model only has one exhaust... There is no air intake. What do you mean?
Old 04-05-13, 03:01 PM
lawrosa's Avatar
Super Moderator
Old 04-05-13, 04:59 PM
Smile parallel option
The Rinnai E110C comes from the factory with the adapters and option to vent it with a two pipe PVC system. Instead of the concentric two pipe set up, you can pop out a 3" plug and convert it in just a couple minutes. Very simple and smart on Rinnai's part. No cutting, just plug in o-ring style adapters to accept 3 inch PVC.
Old 04-05-13, 06:41 PM
rbeck's Avatar
Received 1 Vote on 1 Post
They do not mention it but 6" is normal to be outside the turbulent flow area of wind hitting the wall.
