Help replacing expansion tank.
Old 04-25-13, 07:47 PM
I need help replacing a leaky expansion tank. My plan was to
1. turn off system.
2. Close zone valves to minimize water loss.
3. depressurize system
4. remove tank.
5. install new tank.
6. reverse process.
I was examining my system tonight and there is some sort of triangle shaped check valve? on top of the expansion tank. It' piped into on both sides. One side looks like a union so I'm pretty sure I can get it off.
What is this thing? Do I need it?
(of course my pics won't upload)
Old 04-25-13, 08:21 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
If you can't get the pics to upload here it may be because they are too large.
Easiest way is probably to set up a free account at Photo and image hosting, free photo galleries, photo editing and upload them to a PUBLIC album there. Come back here and post a link to the album for us to view.
Old 04-25-13, 08:27 PM
Received 2 Votes on 2 Posts
Just a guess but if brass maybe pos fill-trol.
Old 04-26-13, 06:19 AM
Finally! Here are the pictures
Old 04-26-13, 07:25 AM
Good guess guyold. I did a search for fil-trol and that is it!! Now what do I do with it? Do I have to replace it with the same type?
Old 04-26-13, 07:39 AM
NJT's Avatar
NJT
NJT is offline
The tank itself is leaking? Can't really see a leak in the pics.
Yes, you need to replace that tank with a Fill-Trol tank. You can not use an 'off the shelf' type because it will not have the 'push rod' that the Fill-Trol tanks have.
Old 04-26-13, 08:04 AM
Yes it is leaking. There is a large rusty scale area in the shadow. It now has a drip about every 30 seconds.
Old 04-26-13, 03:34 PM
NJT's Avatar
NJT
NJT is offline
Why has the water softener been disconnected? Not a bad thing to have ya know... IF it works...
As mentioned previously, you do have to use a Fill-Trol tank with that valve. You do NOT have to replace the whole valve...
I suspect that is a model #110 ? If so, here is a source for your tank:
110-002 - Amtrol 110-002 - Model 110 Fill-Trol, Tank Only (4.4 Gallon Volume)
Here's the install instructions, explains a bit about the Fill-Trol system:
http://s3.pexsupply.com/manuals/1249...filltrolIO.pdf
Old 04-29-13, 11:15 AM
The water softener has not been disconnected. Although the supply for my system is before the softener.
I was able just to unscrew the old tank and pop the new one on. With a little effort. It wasn't easy grabbing on to the tank alone without the valve as they don't give you a lot of room. I wasn't sure if the valve was part of the tank until I was at the plumbing supply store. $115 later and I was out the door with just a tank.
I'm pretty happy overall. The job went easily and quickly. You usually can't complain too much about that. Although half the price would have been better. Next time I will know.
I have been in this house for 2 years and this is the only time I have lived in a house with a boiler system.
Happy ending to a rusty tank. Thanks for all the help.
Old 12-12-13, 07:59 AM
110 fill -trol
So if I just isolate the tank I can just unscrew it and screw the new one in place and Im good to go ?
Old 12-12-13, 09:10 AM
NJT's Avatar
NJT
NJT is offline
If you CAN isolate the tank... is there a valve between the Fill-Trol valve and the boiler?
You also need a shutoff in the line from the water supply. If your fill-trol valve is the type with the shutoff valve built-in, you need to close that valve.
