slant fin liberty 2 oil burn/ hot water furnace install?
Old 08-05-13, 11:32 AM
hello,
installing a new liberty 2 slant fin oil furnace with tankless hot water coil(home depot unit). 2 zone system.
everything was going smooth until the electrical part.
its has a honeywell L7224C auqastat.
it came pretty much wired except for the circulator pump which is a taco unit.
can't figure out which terminals on the auqastat to wire the circulator to.
also when i opened the other box that is mounted to the furnace only the red wire and green wire coming off the beckett burner are hooked up. there is one white and one black wire not connected to anything, but it looks like they connect to the other white and black wires that go to the aquastat and they are hooked into terminal L2 and L1.
if i am missing any other info please let me know.
any help would be greatly appreciated.
thanks
Anthony
Old 08-05-13, 03:03 PM
as i countinue to study the directions, i see that my circulator is already hooked up to the C1 and C2. does the main power get hooked up to the L1 & L2 with the burner wires on the same terminal?
thanks
